Building Supply Chain Resilience: Why MOM Succeeds Where Standalone MES Fails
Originally published on DELMIA Blog by Louis Columbus.
Read how supply chain resilience is not something you bolt onto existing operations after a disruption exposes your weaknesses. It has to be engineered into the way you run every plant, every day. MES gives you control of the shop floor. MOM gives you command of the network.
The ROI Gap: Why Tracking Production Isn’t Enough in 2026
Supply chains don’t break all at once. They erode. A tariff announcement reshuffles sourcing economics overnight. A port closure in Southeast Asia strands \\\$40 million in components. A key supplier quietly declares force majeure while your planning team is still running last Tuesday’s production schedule.
I have spent years covering how manufacturers respond to these moments, and the pattern is consistent. Organizations with a Manufacturing Execution System (MES) controlling each plant can usually tell you what happened. Organizations with a Manufacturing Operations Management (MOM) strategy spanning those plants can tell you what to do about it. That difference matters more than most technology conversations acknowledge.
According to a McKinsey survey of 100 global supply chain leaders, 82% reported their supply chains were affected by new tariffs in 2025, with 20% to 40% of their total supply chain activity disrupted in some way. Meanwhile, the Business Continuity Institute found that roughly 80% of organizations encountered at least one supply chain disruption in the past year. These aren’t edge cases. They are the operating environment.
MES vs. MOM: From Shop Floor Tracking to Global Network Orchestration
Here is where the MES-versus-MOM distinction stops being an academic exercise and starts costing real money.
MES is a shop floor leader. It tracks production in a single facility, enforces work instructions, logs quality data and ensures that the build sequence runs as planned. For one plant, that is exactly what you need. But supply chain resilience isn’t a single-plant problem. When a disruption hits, the question isn’t whether Plant A can finish today’s orders. The question is whether the entire network can reroute, rebalance and recover while meeting customer commitments across every region served.
MOM is the executive strategist. It sits above individual MES instances and connects production execution to quality management, materials logistics, maintenance scheduling and workforce planning. As Mike Bradford, business development director for DELMIA Apriso at Dassault Systèmes, has explained across multiple industry publications, MOM doesn’t replace MES or ERP. It connects and extends them. When a supplier issue surfaces or a substitute material gets approved, the change is recorded once and propagated to every facility instantly. That is the architectural shift that transforms reactive scrambling into a coordinated response.
Bradford has put it plainly: traditional production systems tracked isolated operations, whereas modern MOM platforms unify quality, maintenance, inventory and workforce management in one digital system. The practical implication is that twenty MES instances won’t spontaneously align with each other when trade conditions shift. A MOM platform makes that alignment its central purpose.
Structural Pressures Forcing the Shift to Unified Operations
The MOM software market is growing because manufacturers are learning these lessons the hard way. IMARC Group valued the global manufacturing operations management software market at \\\$13.7 billion in 2025, projecting a compound annual growth rate of 7.82% through 2034. Grand View Research pegged the market even higher, estimating \\\$17.46 billion in 2024 and forecasting growth to \\\$76.71 billion by 2033 at a 19.1% CAGR. Regardless of which estimate you prefer, the trajectory is unmistakable: manufacturers are investing in operational orchestration, not just execution tracking.
Three converging pressures explain the urgency.
1. Structural Tariff Volatility (The New Normal)
Tariff volatility is structural, not temporary. In 2025, U.S. tariffs on steel and aluminum doubled to 50%, reshaping global trade flows across automotive, construction and general manufacturing. Deloitte reported that 73% of U.S. manufacturers cited trade uncertainties as a top business challenge in the first quarter of 2025, up sharply from 37% just two quarters prior. McKinsey’s risk pulse survey found that 45% of companies facing tariff impacts were increasing inventories as mitigation, 39% were pursuing dual sourcing and 33% were developing nearshoring plans. Every one of those responses demands coordinated, multi-plant execution. The kind MOM provides and standalone MES cannot.
2. Closing the Visibility Gap
Visibility gaps are widening. Only 6% of businesses report having full supply chain visibility, according to a 2025 industry analysis from Procurement Tactics. McKinsey’s 2025 survey confirmed that across sectors, the majority of companies understand their supply chain risks only up to tier one. MES tells you what is happening inside your four walls. MOM connects those walls to procurement, logistics and customer commitments, closing the gap between shop floor reality and enterprise-level decision-making.
3. Solving the Manufacturing Skills Shortage with Digital Templates
Workforce constraints amplify every other disruption. Deloitte projects the manufacturing sector will require approximately 3.8 million new employees between now and 2033, with roughly half those positions expected to remain unfilled unless the skills gap is addressed. When experienced operators retire and new hires take longer to reach proficiency, you cannot afford to run each plant as its own island of institutional knowledge. MOM platforms capture manufacturing knowledge as digital templates, including recipes, inspection plans and work instructions, that travel with the product and standardize training regardless of location.
What unified operations actually look like in practice
Theory is helpful. Execution is what pays the bills.
A unified MES/MOM platform like DELMIA Apriso operates as a living execution backbone for global manufacturers. Major customers in automotive, aerospace and industrial equipment run the platform across dozens of plants, some well over a hundred. These are not pilot programs. They are production-scale deployments where every facility shares the same digital thread for process definitions, quality standards and production metrics.
The practical mechanics work like this: engineering or continuous improvement teams design a global process template representing the best-known way to execute a particular operation. DELMIA Apriso propagates that template to every relevant site. Each plant can configure approved local variations, whether different equipment models, regional regulatory requirements or specific material grades, but the core process and metrics stay governed centrally. When a process improvement is validated, it deploys to all sites instantly with full traceability. No waiting for twenty disconnected systems to be updated individually.
Case Study: How BorgWarner Unified Global Manufacturing Silos
BorgWarner, a global automotive supplier operating manufacturing sites across multiple countries, offers a concrete example. As William Sun, General Manager, described it:
DELMIA Apriso broke through these silos to form a connected environment with complete closed-loop control from incoming material inspection to material use, manufacturing process, product testing, and warehousing logistics.
That connected environment is the difference between knowing what happened at a single plant and orchestrating a response across an entire manufacturing network.
For supply chain resilience specifically, this architecture delivers three critical capabilities. First, when a shipment is delayed, production schedules and work instructions adjust across affected facilities in real time, preventing bottlenecks from cascading. Second, embedded analytics combine production metrics, supply information and quality indicators in real-time dashboards, enabling pattern detection that flags potential disruptions before they fully materialize. Third, digital twins allow manufacturers to simulate production line changes virtually, testing layouts, equipment configurations, staffing levels and alternative material flows before committing capital.
Is MOM Scalable for Mid-Tier Manufacturers?
MOM strategy is sometimes perceived as an enterprise-only conversation. It shouldn’t be. Mid-tier manufacturers face the same disruption forces, from tariff shifts and supplier concentration risk to workforce shortages, with thinner margins for error and smaller teams to manage response. The transition from fragmented MES to unified MOM mirrors a journey many mid-tier companies already understand: moving from QuickBooks-level tools to integrated ERP. The same logic applies on the shop floor. You outgrow point solutions when you need consistent data across facilities to make confident decisions under pressure.
DELMIAWorks provides a practical MOM entry point for manufacturers scaling beyond basic MES. It proves that modern MOM is accessible to mid-tier organizations without requiring enterprise-scale complexity. Configurability rather than customization is the key architectural principle, the same principle that allows operations to scale without accumulating technical debt.
Bottom line
Supply chain resilience is not something you bolt onto existing operations after a disruption exposes your weaknesses. It has to be engineered into the way you run every plant, every day. MES gives you control of the shop floor. MOM gives you command of the network. In an operating environment where 82% of global supply chain leaders report tariff impacts and 94% of companies have experienced revenue losses from disruption, the question is no longer whether to invest in MOM. It is whether you invest before the next disruption or after it has already cost you. Manufacturing markets will not decelerate. Supply chains will not spontaneously stabilize. The companies building unified execution backbones today are the ones that will define manufacturing standards tomorrow. Those delaying face increasingly difficult recovery as digitally enabled competitors convert operational advantages into lasting market leadership.
For more information click here.
Written by Louis Columbus
Louis Columbus is currently serving as a member of the DELMIA Marketing team, where he assists with DELMIAWorks and robotics solutions. Previous positions include product management at Ingram Cloud, product marketing at iBASEt, Plex Systems, senior analyst at AMR Research (now Gartner), marketing and business development at Cincom Systems, Ingram Micro, a SaaS start-up and at hardware companies. Professional experience includes marketing, product management, sales and industry analyst roles in the enterprise software and IT industries. Columbus' academic background includes an MBA from Pepperdine University and completion of the Strategic Marketing Management and Digital Marketing Programs at the Stanford University Graduate School of Business. He teaches MBA courses in international business, global competitive strategies, international market research, and capstone courses in strategic planning and market research. Columbus has taught at California State University, Fullerton: University of California, Irvine; Marymount University, and Webster University.
