In Discovery Studio by default, the job folder of a job will be saved to the Discovery Studio>Results (or Discovery Studio Simulation>Results) folder on your client machine. If you want to change this location e.g. to keep jobs of a particular project together in a separate folder you can change the default folder location before you run the job. The easiest way to do this is the following:
1. Open the Files Explorer in the Discovery Studio client
2. Locate the folder you wish to select as your new default folder location.
3. Select the folder, right-click, select Set as Default from the context menu. A blue square appears around the icon for this folder. Any protocols that you run subsequently will save their job folders to this new default folder.
