PURPOSE: Uses the Minimization protocol on several input typed systems. To select several proteins on the Input Typed Molecule parameter open the dropdown menu and select Browse... Once selected a pop up will appear, here select several dsv files with typed proteins. Constrains can only be applied to all the minimized systems, no specific constrains for each system.
USAGE: This protocol can be launched from both the Discovery Studio and Pipeline Pilot clients. To install in Discovery Studio, open the file in Pipeline Pilot and save it under your username. Then, on the Discovery Studio Client on the Protocol Explorer, right-click over your username folder and click refresh.
REQUIREMENTS: Discovery Studio Collection.
DISCLAIMER: This custom script is compatible with Discovery Studio 2024. The code or software provided by Dassault Systemes Biovia Corp. ("BIOVIA") in conjunction with this request is provided under the same license terms and restrictions as the underlying BIOVIA software it is intended to be used with, including license duration and location based restrictions, with the following exceptions. This software is provided on an AS-IS and AS-AVAILABLE basis with no guarantee or warranty, and is not subject to maintenance, updates, or support. When your license to use the underlying BIOVIA software terminates, your license to use this software will also terminate. BIOVIA makes no warranty that this software will be usable for any purpose.
